17 years agoproblems with programming neek
Hello, I've recently bought a neek kit. I tried all found niosII examples design, for example this standard one http://www.altera.com/support/examples/nios2/exm-std_nios2_hardware.html Ge...
16 years agoIt is normal. The license you are missing is for the IPs that you put in the FPGA, probably the NIOS itself. You can still configure your board and use it though, just keep the USB cable connected and don't close the alert window opened by the programmer.
