15 years agoproblems with clock !!
Hi, I can't see the clock on the oscilloscope, i need this test to see if it works, then i'll use it for Nios.
I test the clock_50 with this code: entity provaClock is port(CLOCK_50: in std_logic; uscita :out std_logic ); end entity provaClock; architecture ar of provaClock is signal coll :std_logic; begin coll<=CLOCK_50; uscita<=coll; end ar; FPGA Cyclone ii PIN Assignment uscita --- PIN_K20 CLOCK_50 -- PIN_B12 Software Quartus 9.1 Web Edition why ????? Thanks2 Replies
Sorry Sorry Sorry, but the Oscilloscope is to 100 Mhz and it did not have the appropriate resolution!!!
Thanks a lot!! - Altera_Forum
Where are you probing the signal? K20 or B12.
The clock is an external signal. Your design simply pass the signal from pin B12 to K20. Can you see the clock entering B12?
