15 years agoproblems with clock !!
Hi, I can't see the clock on the oscilloscope, i need this test to see if it works, then i'll use it for Nios. I test the clock_50 with this code: entity provaClock is port(CLOCK_5...
15 years agoWhere are you probing the signal? K20 or B12.
The clock is an external signal. Your design simply pass the signal from pin B12 to K20. Can you see the clock entering B12?
