Problems interfacing to Arria10
Hello, I just got started with the Arria10 Dev kit revE3.1 and am having some issues
The machine I am working on runs Red Hat Enterprise Linux Workstation 7.8
I have Quartus Prime 17.1 along with the Arria10 Developers Kit Package installed.
I have been following the User guide for this board and tried running the Board Test System. I got the BTS to run by executing the bts.jar file in the arria10 Developers Kit Package but i have not had much success getting it to work.
I have the board connected to my network and I have the IP address showing on the board but the BTS just says "connecting..." and shows Web Link Address 192.168.1.100 however the board shows 192.168.0.21, I can hit refresh on the BTS which refreshes the board but still the same problem. I can connect to the web server associated with the IP address though.
When i try to run a design i get an error that says "Failed to get this device. Pleas make sure system console is closed. Close this GUI and check the board connection."
I also see an error in terminal and i'm not sure what that means at the moment.
SEVERE: java.util.concurrent.ExecutionException: java.lang.NumberFormatException: For input string: "USB-BlasterII on localhost (3-6)"
On another note I have also tried following a tutorial on RocketBoards.org to build and install U-boot . I am following the instructions there to program QSPI flash and upon running:
~/intelFPGA_pro/20.1/embedded/embedded_command_shell.sh \ quartus_hps -c 1 -o pv -a 0x0000000 u-boot-splx4.sfp
I get the following error in terminal:
Error: Unable to detect HPS device Error: Quartus Prime Programmer was unsuccessful. 0 errors, 0 warnings Error: Peak virtual memory: 213 megabytes Error: Processing ended: Fri Jan 15 13:42:46 2021 Error: Elapsed time: 00:00:04 Error: Total CPU time (on all processors): 00:00:00
Thanks for your time!
- EricMunYew_C_Intel
You have to install USB Blaster II driver from your Quartus Pro installation path.
- Deshi_Intel
BTS is meant for Win OS only so it may not be compatible with Linux OS. If you have Win OS then perhaps you can try out BTS.
dlim
- alex_ander
ok, thanks for letting me know.
Would you happen to know why I am having problems talking to the HPS using the HPS programmer? every command I try to talk to the HPS returns an error saying unable to detect HPS device. I am using the arria10 board. I am not sure why i keep getting this error.
