14 years agoproblem with writing testbench
hi
I installed a qurtusii web edition included a modelsim 6.5 i've written a counter code in verilog and a simple testbench also. when i compile the code in quartus there is no error but in modelsim when inputs change there is no change in output. thank you this is the code. module counter4bit ( input clk, input enable, input reset, output reg [3:0] outbits ); reg [3:0] counter ; always @ (posedge clk) begin if(enable == 1) begin if(reset == 1) begin counter <= 4'b0000; end else begin counter <= counter +1 ; outbits <= counter ; end end else begin outbits = counter ; end end endmodule module count_t () ; reg resett, enablet,clkt ; wire [3:0] out ; counter4bit c1( clkt, enablet, resett, out ); initial begin resett = 0 ; clkt = 1 ; enablet = 0 ; # 10 enablet = 1 ; end always # 20 clkt = ~clkt ; endmodule2 Replies
thank you rbugalho
You are not resetting your counter to zero, which you must, because modelsim will start with counter set to 'UUUU'.
Also, note that in your module, the reset is synchronous and subject to the enable signal. Thus, you need to have enable = 1 and reset = 1 long enough for count to reset to zero.
