18 years agoProblem with WHILE Loop
I am currently trying to compile and simulate a vhdl ROM file. I am having problem with the while loop, which is used to read the ROM. The following is the vhdl-code: entity mc8051_rom is ...
16 years agoWe can modify/update the record data of a form by looping through its records. So, we are generally following the below code to do the same.
// loop through the records var count = 1; var maxCount = controller.getMaxRecordIndex(); for(var count=1; count<=maxCount; count++) { // select the record controller.setSelectedIndex(count); /* Do any operations with the selected record */ } Hope this information is useful.Any suggestions are appreciated.
