18 years agoProblem with WHILE Loop
I am currently trying to compile and simulate a vhdl ROM file. I am having problem with the while loop, which is used to read the ROM. The following is the vhdl-code: entity mc8051_rom is ...
18 years agoi want to simulate it. but before simulating it in Quartus II, i must compile it first, right?
because of that error, the compilation could not be completed. i tried to solve the problem by creating 8 while-loops with each loop consists of iteration less than 10000. The following is the vhdl-codes: if (not s_init) then v_loop := 0; while (v_loop < 8000) loop readline(f_initfile,v_line); read(v_line,v_rom_data(v_loop)); v_loop := v_loop + 1; end loop; v_loop := 8000; while (v_loop < 16000 ) loop readline(f_initfile,v_line); read(v_line,v_rom_data(v_loop)); v_loop := v_loop + 1; end loop; v_loop := 16000; while (v_loop < 24000 ) loop readline(f_initfile,v_line); read(v_line,v_rom_data(v_loop)); v_loop := v_loop + 1; end loop; v_loop := 24000; while (v_loop < 32000 ) loop readline(f_initfile,v_line); read(v_line,v_rom_data(v_loop)); v_loop := v_loop + 1; end loop; v_loop := 32000; while (v_loop < 40000 ) loop readline(f_initfile,v_line); read(v_line,v_rom_data(v_loop)); v_loop := v_loop + 1; end loop; v_loop := 40000; while (v_loop < 48000 ) loop readline(f_initfile,v_line); read(v_line,v_rom_data(v_loop)); v_loop := v_loop + 1; end loop; v_loop := 48000; while (v_loop < 56000 ) loop readline(f_initfile,v_line); read(v_line,v_rom_data(v_loop)); v_loop := v_loop + 1; end loop; v_loop := 56000; while (v_loop < 64000 ) loop readline(f_initfile,v_line); read(v_line,v_rom_data(v_loop)); v_loop := v_loop + 1; end loop; v_loop := 64000; while ((not endfile(f_initfile) and (v_loop < 65535)) loop readline(f_initfile,v_line); read(v_line,v_rom_data(v_loop)); v_loop := v_loop + 1; end loop; s_init <= true; end if; but then i got the error statement: "error: vhdl error at mc8051_rom.vhd(153): index value 65536 is outside the range (65535 downto 0) of object "v_rom_data"" what should i do next?
