12 years agoProblem with using Inverse FFT Megacore
I have a megacore FFT (length=32768, Buffered Burst) on the fpga and sending it data from the ARM processor (Cyclone V SoC) I can successfully perform FFT on data. But when I use the same cor...
12 years agoHi Kaz. Thanks for that. Keeping the inverse at '1' throughout the frame helped. Now it does calculate the Inverse.
I just always thought it was a pulse because in the guide it said " Inverse FFT calculated if asserted. Only sampled at SOP" So I figured it checks for inverse input only at the sop. I guess that was a bad assumption to make. Thanks for the help.
