16 years agoproblem with the voltage of the output pin
I have used the CPLD for my project. And the device is EPM7128STC100-10(Max7000 series ) ,the voltage of Vccio is 5v,but the output voltage of the I/O is 3.16v. I have defined the I/O standard a...
16 years agoCan you tell me that whether Voh>2.4v is under the condition that there isn't any intentional load connected to the pin.
Thank you! ps:I have try my best,but it doesn't work .can you check the schematic diagram for me. --- Quote Start --- It's a valid TTL high level (>2.4V), and according to the MAX7000 datasheet, it's normal operation. The specification is Voh > 2.4V @ Ioh = -4mA, although the typical current capability is higher according to the diagram. But if you havn't any intentional load connected to the pin, you may want to check what's going on in your circuit. --- Quote End ---
