16 years ago
Problem with Target connection
I build my own component in SOPC Builder. It gets added into the component list . Everything seems to be working fine. But, when I am trying to run simple hello_world template, it is giving error in target connection.
I tried downloading .sof file. It shows progress as 100%. But while running the project it gives error:
[Target Connection]: no Nios II path were located. Check connections and that a Nios II .sof file is downloaded.
Mumble.
    The problem seems to be with Nios II, not with your component. Check Nios configuration in sopc builder, in particular jtag debug settings.
    Did you previously test your design without the custom component? Did it work?
    Cris
