16 years agoProblem with Target connection
Hi, I build my own component in SOPC Builder. It gets added into the component list . Everything seems to be working fine. But, when I am trying to run simple hello_world template, it is givin...
16 years agoHi Mumble,
Signal check: I presume you can easily do it with the SignalTap feature. Anyway I'm quite new to Altera, too and I never used it because I worked more on software side; so I can't give you better hints than looking at the signaltap manual or some tutorial. For what I've done so far on the hw side, it was enough the raw old method: connecting signals to be tested to some fpga spare pins and recompiling; you can do this if your design recompiles fast. System id: Have you any failing timing in Quartus? If not, it could be that something of the previous configuration is still around. Have you rebuilt everything? As a last option I'd suggest to create a new project from scratch, with the same source files. Regards Cris
