14 years agoProblem with state machine (AHDL)
Hi all,
i'm a newbie in ADHL programming and have a problem with the code of the state machine below. I tested it on my CPLD-Board (MAX II). The machine works well when the signal "relais" is in LOW-state. When "relais" is on HIGH-state, i think the state machine doesnt jump in the "ignore" state. I cant see the bug of the code.
SUBDESIGN ignore_signal
comp_in, relais, reset, CPLD_CLK : INPUT;
comp_out : OUTPUT;
VARIABLE ignore_machine : MACHINE WITH STATES(init, ignore, high, ignored);
counter : DFF;
BEGIN
counter.clk = CPLD_CLK;
CASE ignore_machine IS
WHEN init =>
comp_out = GND;
IF relais THEN
counter = 0;
ignore_machine = ignore;
ELSIF comp_in THEN
comp_out = VCC;
ignore_machine = high;
ELSE
ignore_machine = init;
END IF;
WHEN ignore =>
comp_out = GND;
counter = counter+1;
IF counter >= 1200000 THEN
comp_out=VCC;
IF comp_in THEN
comp_out = VCC;
ELSE
comp_out = GND;
ignore_machine = ignored;
END IF;
ELSE
END IF;
WHEN high =>
comp_out = VCC;
IF !reset THEN
comp_out = GND;
ELSE
comp_out = VCC;
END IF;
WHEN ignored =>
comp_out = GND;
IF comp_in THEN
comp_out = VCC;
ELSIF !relais OR !reset THEN
comp_out = GND;
ELSE
comp_out = GND;
END IF;
END CASE;
END;
1 Reply
first of all - AHDL is an old and now unsupported language. I highly suggest you move to a language that you can simulate, like VHDL or Verilog.
Secondly, are comp_in and relais synchronous signals? if not, you may be getting glitches. And where is the synchronous register for the state machine?
