16 years agoProblem with QUARTUS II 9.1 SOPC & NIOS II character LCD
hello everyone… I am attempting to get the Character LCD working with NIOS II control. According to the documentation if I have set it up correctly then a simple printf() statement will redirect t...
16 years agoFirst you need to check if you have enough memory, if you use the On-chip memory it cannot work with printf() function, you should try to insert SDRAM in SOPC builder and then you have to assign pins correctly to connect your external SDRAM and the Nios with quartus, after you can check if the memory is working well. After you can try to start it again your project to display something on the screen. Good luck !
