17 years agoProblem with PLL in EP1C12 device
Hello everyone, long time no see =] Recently I've built my own evaluation board with EP1C12 Cyclone device (yes, it's an old one, but I obtained it for free). The board is working, I can config...
17 years ago --- Quote Start --- I forgot to mention that in timing simulation everything is OK. --- Quote End --- So it should work in hardware as well. Are you sure to have assigned the pins correctly? You didn't mention a particular problem that you experienced with your design.
