12 years ago
Problem with parameter settings in fir compiler v8.0
Hi all, I have a technical problem with the coefficients parameter settings- i have inserted the required parameters in the coefficients generator dialog box (a screen shot is attached) but when i check the text file (generated by the wizard) that records the parameters, i see that the only parameter which is saved is the number of the coefficients, all the other parameters (filter type, sample rate and the cutoff frequencies) stayed with their default values (the parameters output file is attached as well). What could be the reason to that problem? Thanks!
