9 years agoProblem with NIOS2 Flash Programmer --> Quartus II 16.1 version
Hallo there, a while back I had asked some questions regarding packing the .sof and .elf files in to one file to be copied directly to the Flash device. This has worked fine on Quartus 11sp1. N...
9 years agoIs it a genuine EPCS64 device, or a third party serial FLASH device with the same capacity? The Nios programmer only supports a small number of serial FLASH parts by default - including genuine Altera/Intel EPCS64 devices.
Have a look at this post: http://www.alteraforum.com/forum/showthread.php?t=44094&highlight=flash-override which discusses how to allow the Nios programmer to support other FLASH devices. Note: what you add to your nios2-flash-override file might not be exactly as discussed in the post - this depends on the exact device you have fitted. If this doesn't solve it attach the whole trace from the Nios programmer to this post. Cheers, Alex
