16 years ago
problem with ModelSim
I use ModelSim to simulate an adder(sumador.vdh) and a testbench(bancopruebas.vdh) that read a text file "Datos.txt" where the data are;and put the result in other file "resultados.txt". After I compiled without problem and try to load in the simulator appear the mgs:# Loading work.bancopruebas(estructura)# ** Error: (vsim-3173) Entity 'C:\altera\90\modelsim_ase\examples\work.sumador' has no architecture.
It's rare becouse I declared "sumador.vdh" as a component of "bancopruebas.vdh"
Any clue about this?
    to be honest the problem was not from de modelsim, it was me due to the way I wrote the VHDL code ...:rolleyes:
    once again you got the reason...
    I put suma<=OpA + OpB in sumador' architecture and it work perfect
    with the result that I expected.....
    THANK A LOT TRICKY!!!!!!!!!!!!!!!!!!!
    probably because you forgot the line:
    suma <= OpA_I + OpB_I;
    but even this is going to have your results lagging by 1 result because suma is a signal and not a variable.
    thank tricky , it work!!!! but not with the result I expected
    I hve to check ...thank anyway....
    But you do need an architecture - the architecture defines how sumador works. Without one sumador doesnt exist.
    The quickest way to fix it would be to comment out the sumador instantiation and the component or just add an empty architecture.
    Sorry the extension are vhd, here are the sources:
    library ieee;
    use std.textio.all;
    entity bancopruebas is
    end bancopruebas;
    architecture estructura of bancopruebas is
    signal OpA,OpB,suma:integer;
    component sumador
    port(OpA: in integer;
    OpB: in integer;
    suma : out integer);
    end component;
    begin --proceso que lee los estimulos y graba los resultados
    process
    constant Periodo :time:= 100 ns;
    file Datos :text is in "Datos.txt";
    variable lineadatos :line;
    file resultados :text is out "resultados.txt";
    variable linearesultados :line;
    variable OpA_I,OpB_I :integer;
    begin
    while not endfile(Datos) loop
    readline(Datos,lineadatos); --
    read(lineadatos,OpA_I);
    read(lineadatos,OpB_I);
    OpA <= OpA_I;
    OpB <= OpB_I;
    wait for Periodo;
    write(linearesultados,OpA);
    if OpB_I < 0 then
    write(linearesultados,string'("-"));
    else
    write(linearesultados,string'("+"));
    end if;
    write(linearesultados,abs(OpB));
    write(linearesultados,string'("="));
    write(linearesultados,suma);
    writeline(resultados,linearesultados);
    end loop;
    wait;
    end process;
    -- Referencia al sumador
    sumador0: sumador port map(OpA,OpB,suma);
    end estructura;
    ---------------and the sumador is
    entity sumador is
    port(OpA : in integer;
    OpB : in integer;
    end sumador;
    as you can see I dont need architecture here becouse the first program do the job
    This error would imply that sumador has no architecture associated with its entity.
    why are all your file extensions .vdh instead of the standard .vhd?
    you also dont declare .vhd files as components, its the entity name thats important (usualy the same name as the filename).
