16 years agoproblem with ModelSim
I use ModelSim to simulate an adder(sumador.vdh) and a testbench(bancopruebas.vdh) that read a text file "Datos.txt" where the data are;and put the result in other file "resultados.txt". After I comp...
16 years agoThis error would imply that sumador has no architecture associated with its entity.
why are all your file extensions .vdh instead of the standard .vhd? you also dont declare .vhd files as components, its the entity name thats important (usualy the same name as the filename).
