16 years agoproblem with cyclone III and jtag
I would like to put a very serious discussion about using jtag with cyclone III. has cyclone3 less electrical tolerance compared to other FPGA's?????? . we are building a custom board. and t...
16 years agoIt shouldn't damage the FPGA, as long as the voltage never goes above 4.1V. The I/O voltage used for the JTAG pins is the same than for bank 1, and extra care should be taken if you are using a supply voltage of 3.0 or 3.3v.
Any high speed buffer should do the trick. We use 74LVC541 chips and they work fine.
