16 years agoPage 9-49 of the Cyclone III datasheet:
http://www.altera.com/literature/hb/cyc3/cyc3_ciii51016.pdf reads: --- Quote Start --- For device VCCIO of 2.5, 3.0, and 3.3 V, refer to Figure 9–24. All I/O inputs must maintain a maximum AC voltage of 4.1 V. Because JTAG pins do not have the internal PCI clamping diodes to prevent voltage overshoot when using VCCIO of 2.5, 3.0, and 3.3 V, you must power up the VCC of the download cable with a 2.5-V supply from VCCA. --- Quote End --- It is unfortunate that this was overlooked. You say the boards had been working and have failed. It is possible that the FPGA has been damaged. Jake
