17 years agoProblem with C2H
Hi, I have given a long C code to C2H for converting to HDL. On first run it gives error saying something like: Adrdress range of uart1.s1 overlaps with pll.s1, etc. In this run I used "...
17 years agoWhen I first use C2H in nios ii 8.1,some errors occur .That is because the nios II 8.1 need a path which called "PC-NIOS_II-8.1-0.01.exe". After fix the path, I can use the C2H.
