18 years agoproblem using altclkctrl...any suggestions
I have to be able to shutdown a clock to different sections of logic for power saving purposes. I generate this clock via a pll from a master input clock. I then need to run this clock to 6 altclkc...
16 years ago --- Quote Start --- I have to be able to shutdown a clock to different sections of logic for power saving purposes. I generate this clock via a pll from a master input clock. I then need to run this clock to 6 altclkctrl blocks to selectively enable/disable this clock to various sections of logic. The logic blocks are part of a large pipeline and data flows thru them, depending on which clocks are enabled. I can't split up the pll that generates this clock into 6 different plls as I'm pretty much out of plls in the chip. When I synthesize, I get an error that basically says "Can't place node clk0 (pll output). Requires 7 clock signals which exceeds max of 6." Does anybody have any ideas or has dealt with this type of situation before? The device is a Stratix2. Thanks. --- Quote End --- Hi, can you post a drawing or project in the forum ? Kind regards GPK
