18 years agoProblem uploading design to Cylone II
Hi, i have the nios development board (cyclone II edition), which has an altera cyclone II EP2C35F672C6 FPGA. The problem i'm facing is that everytime i use the quartus 2 programmer to upl...
18 years agoI've seen similar behaviour when the setting "Reserved all unused pins" are set to output driving ground. I think it has something to do with the FPGA grounding a active low signal to the configuration CPLD, which activates reprogramming of factory settings. If you haven't already done this set unused pins to "input tri-stated".
//Ola
