JBouv2
6 years agoproblem to program an arria10GX with active serial
Dear all, I am working on a card based on ARRIA10GX. I want to program the FPGA with the active serial configuration. I programmed the flash memory (MT25QU01G) a first time but unfortunately the f...
JBouv2
6 years agoHi
the problem is almost solved, I managed to access the flash memory and erase it. now when the power is turned on the FPGA does not reboot indefinitely. I think the other part of the problem is the generation of the .RPD file. and the sequence of my script there must not be in agreement I will check.
actually on the oscilloscope I looked at the pin AS_DATA0.
for the generation of the .RPD file the information is good except for the little / big endian coding I am no longer sure.
No I do not access the FLASH by the JTAG, this one allows me to program the FPGA and to access the card therefore to the FPGA by a PCIe link to be able to execute my script
thanks again for your time
regards
