JBouv2
6 years agoproblem to program an arria10GX with active serial
Dear all, I am working on a card based on ARRIA10GX. I want to program the FPGA with the active serial configuration. I programmed the flash memory (MT25QU01G) a first time but unfortunately the f...
NurAiman_M_Intel
6 years agoHi,
I think it is not appropriate to check the signal in that way. It would be better if you could boot the FPGA and the probe the configuration pin using osilloscope. Can you do that? if so, can you let me know the signal?
At the same time, can you please check if your hardware connection is connected as shown in user guide below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/arria-10/a10_handbook.pdf (Page 228)
Also, can you please check if you configuration pin is connected as per our pin connection guidelines:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/arria-10/PCG-01017.pdf (Page 7)
Aiman
