JBouv2
6 years agoproblem to program an arria10GX with active serial
Dear all, I am working on a card based on ARRIA10GX. I want to program the FPGA with the active serial configuration. I programmed the flash memory (MT25QU01G) a first time but unfortunately the f...
JBouv2
6 years agoHi,
hank you for your reply
I am not sure that I generate correctly the .rpd file. In the Convert Programming File program I select little endian order and in my script I am reorder the byte for each 32bit word.
but my problem that now I can't access to the memory flash and I can't replace it
regards
