JBouv2
6 years agoproblem to program an arria10GX with active serial
Dear all, I am working on a card based on ARRIA10GX. I want to program the FPGA with the active serial configuration. I programmed the flash memory (MT25QU01G) a first time but unfortunately the f...
NurAiman_M_Intel
6 years agoHi,
During the conversion from .sof file to .rpd file, did you choose the Endian order correctly? Please bear in mind that you will need to select Big Endian order in order for the configuration to work successfully.
If you have select the correct order and still facing problem, there might be some error in your script.
Thank you.
Aiman
