17 years agoProblem RTL Simulation with ModelSim in Quartus II 9.0
Hello, I've recently installed Quartus II 9.0 and Modelsim-Altera (using the new installation package of 9.0), but when I tried to run Tools/Run RTL Simulation I get the following error message...
17 years agoHi,
I had this problem, you have to set the path of ModelSim in SOPC Builder and in Nios IDE. In SOPC BUIlder select Option and then HDL Simulator. Then put the path of ModelSIm which should be in Altera\90\modelsim_ase\win32aloem. Unfortunately I do not remembered where to indicate the path in Nios IDE but you can try to run your project as Nios II ModelSim and an error should occur telling you to set the path in a specific setting of Nios IDE. Hope it will help éléa
