DMast9's avatar
DMast9
7 years ago
Problem (re-)programming EPCQ16A with NIOS design
I am not able to program an EPCQ16A with an NIOS based design.​
  • Works OK with non-NIOS design until a NIOS deisgn is used. Once the NIOS design is downloaded the PROM appears locked. It can no longer be successfully erased or programmed.
  • I have tried erasing without a design file being specified (to clear all locations).
  • NIOS design will operate if loaded in the FPGA using a JTAG link.
  • Same thing happens on serveral different boards.
The EPCQ16A is returning an ID of 0x14, where I was expecting 0x15 according to the datasheet.
Hardware: Cyclone IV (EP4CE22) and EPCQ16A.
IDE: Quartus Prime 18.1.0 Lite Edition.
Programmer: Terasic USB Blaster.
The EPCQ16A connected directly to Blaster (non-JTAG).
I am guessing that the problem I am seeing may have something to do with the NVCR register in PROM.
Any information/experience that can be shared to overcome this problem would be greatly appreciated.
Darryl
  • ​Problem resolved:
    Issue due to 'Use enhanced mode serial flash loader for factory default helper image'
    being selected in the programmer options.
1 Reply
  • DMast9's avatar
    DMast9
    ​Problem resolved:
