11 years agoProblem programming SPI bitstream flash in AS mode
Hi all!
I designed a board with Cyclone II EP2C35. This is my first design with Altera. The JTAG interface works and the FPGA can be loaded using USB Blaster. The FPGA should be normally configured from SPI bitstream flash in AS mode; we are using Adesto 25DF321A, 32Mbit. Problem is that I cannot program the flash using USB Blaster! Schema: http://www.alteraforum.com/forum/attachment.php?attachmentid=9784&stc=1 Connector X201 is JTAG - works. Connector X202 is AS-mode - does not work. I believe that the FPGA and Flash are connected properly. This is a trace of FPGA->Flash communication after power-up when the FPGA is trying to read bitstream. You can see the FPGA is sending status query and the flash responds. http://www.alteraforum.com/forum/attachment.php?attachmentid=9785&stc=1 Now when I connect USB Blaster and try to program flash in AS-mode I get this weird trace: http://www.alteraforum.com/forum/attachment.php?attachmentid=9786&stc=1 USB Blaster is driving those signals when FPGA_CE is high. The signal FPGA_DCLK no longer looks like a clock. I checked the other signals and none of them does. Programming fails with error messages: Info (209060): Started Programmer operation at Mon Nov 24 09:20:54 2014 Error (209025): Can't recognize silicon ID for device 1 Error (209012): Operation failed Info (209061): Ended Programmer operation at Mon Nov 24 09:20:55 2014 Programmer is set to AS mode, EPCS16: http://www.alteraforum.com/forum/attachment.php?attachmentid=9787&stc=1 I must be sure doing something obvious wrong. Please help! Jara2 Replies
--- Quote Start --- I must be sure doing something obvious wrong. Please help! --- Quote End --- You're doing most things correctly, except for reading the error messages ... --- Quote Start --- Error (209025): Can't recognize silicon ID for device 1 --- Quote End --- Does the Adesto 25DF321A use the same commands as the EPCS devices? If so, then all you need to do is disable the ID check in the Quartus programmer. Cheers, Dave - Altera_Forum
That Adesto flash is Atmel AT25DF321A.
Commands are the same as EPCS16, except of the "Read silicon ID", which is disabled by the option: http://www.alteraforum.com/forum/attachment.php?attachmentid=9795&stc=1 Jara
