16 years agoproblem in program the EPCS16 with jic file in a multiple-FPGA system.
Dear all, In board, there are two EP3C25Q240, they are designed with multi-device AS and JTAG configuration. A EPCS16 is used to configure the two FPGAs. In Jtag mode, I can download the s...
16 years agoThank you,Jerry.
yes, I can get the jic files with convert programmer files tool under QII's file menu. In my case, there are two FPGAs, and one configuration device (EPCS16). Should I convert two sof files (for two FPGAs) into a single jic file? or should I convert two sof files into seperate jic files? I was a bit confused.
