15 years agoProblem in Implementing Autocorrelation on Stratix II EP2S60 DSP Development Board
Hi there, I am trying to synchronize the transmitted signal with the receiver by energy detection. The transmitted signal is a sine wave and I plan to autocorrelate it to obtain the peak and th...
14 years ago --- Quote Start --- I am having a hard time with my ADC. Its AC coupled and changes the signal I send. Could you please send me something about handling the ADC. --- Quote End --- If the ADC is AC coupled, then it will have a low-frequency limit. You need to check the bandwidth of the AC coupling circuit. Is it just some capacitors or is it a balun? Are you using an Altera board, or custom board? There are some spectra in here from the Stratix II DSP Kit: http://www.ovro.caltech.edu/~dwh/correlator/pdf/lfsr_tutorial.pdf The spectrum looks fine at 3MHz (if this is the board you are using). Cheers, Dave
