15 years agoProblem in Implementing Autocorrelation on Stratix II EP2S60 DSP Development Board
Hi there, I am trying to synchronize the transmitted signal with the receiver by energy detection. The transmitted signal is a sine wave and I plan to autocorrelate it to obtain the peak and th...
14 years ago --- Quote Start --- I am working with frequencies of 3MHz(transmitted signal) and trying to make a model of visible light communication. --- Quote End --- That's a little vague. What are you trying to do "in detail". You have a DSP board, what are you sending to the DAC, what are you sending to the ADC? Do you have two boards that are supposed to communicate, or are you just looping things back on the same board? How are the TX and RX connected, eg. just a wire, or are you using the 'visible light communications' interface? What is that interface, and IR source? Are the source and destination using the same clock, or are they asynchronous? What kind of direction have you been given for this project? Cheers, Dave
