17 years agoProblem for simulate PLL with Modelsim-Altera
Problem of simulations Since block Diagram.bdf, I use Run gate-level simulation automatically from EDA simulat Tool of quartusII.7.2 Web Edition I can stimulate the PLL (Altera_mf, Altpll) ...
17 years agoFrom the Menu Simulate->Start Simulation
Select your design unit that you want to simulate and resolution from the pull down called "resolution". Obvious once you've found it! Not Obvious if you haven't! Hope this helps
