17 years agoProblem for simulate PLL with Modelsim-Altera
Problem of simulations Since block Diagram.bdf, I use Run gate-level simulation automatically from EDA simulat Tool of quartusII.7.2 Web Edition I can stimulate the PLL (Altera_mf, Altpll) ...
17 years ago --- Quote Start --- If you observe no output from the PLL without an error message, it's most likely due to the default resolution = ns vsim setting. It must be changed to resolution = ps to simulate a PLL. --- Quote End --- hello, please can you tell me how can i change the resolution of simulator modelsim because whe i simulated the ALTPLL i met a problem and a warning was appeared "time unit 'ps' is less than the simulator resolution(1ns). thank you an advance
