17 years agoProblem delay
I have some problems with a project. In my project there are more inverter chained (chain of inverters). During the compilation, the sinthesis consider only one inverter if the inverters are odd...
17 years agoeven though its dirty, i have done this in VHDL using the keep attribute:
library ieee;
use ieee.std_logic_1164.all;
entity keeplogic is
port(
insig : in std_logic;
outsig : out std_logic;
outkeep : out std_logic
end keeplogic;
architecture rtl of keeplogic is
signal sig_wire : std_logic;
signal keep1_wire : std_logic;
signal keep2_wire : std_logic;
signal keep3_wire : std_logic;
signal keep4_wire : std_logic;
signal keep5_wire : std_logic;
signal keep6_wire : std_logic;
attribute keep: boolean;
attribute keep of keep1_wire: signal is true;
attribute keep of keep2_wire: signal is true;
attribute keep of keep3_wire: signal is true;
attribute keep of keep4_wire: signal is true;
attribute keep of keep5_wire: signal is true;
attribute keep of keep6_wire: signal is true;
begin
--does not preserve not gates
sig_wire <= not( not( not( not( not (not insig)))));
--does preserve not gates
keep1_wire <= not insig;
keep2_wire <= not keep1_wire;
keep3_wire <= not keep2_wire;
keep4_wire <= not keep3_wire;
keep5_wire <= not keep4_wire;
keep6_wire <= not keep5_wire;
outsig <= sig_wire;
outkeep <= keep6_wire;
end;
