Pre emphasis and Equalization in Stratix 10
As I understand it, you seems to observe Fitter error when trying to port a S10 H-Tile device to L-Tile device. For your information, generally it is recommended for you to refer to the H-tile design and then create a fresh design in L-tile device to avoid any incompatibility issue.
By looking merely looking at the current error, it is rather difficult to tell what might be wrong. If you would like to continue debugging on your existing design which was directly ported from S10 H-Tile, it would be great if you could start by trimming the design to only 1 XCVR channel. Then compile to see if it can pass Fitter. This would ease the debugging process.
Chee Pin
- SK_VA6 years ago
Hi ,
I am able to run my transceiver example design with transceiver toolkit.
I performed an auto sweep and eyeviewer on the transceiver links.
I am able to see the BER 0 and best PMA settings in Transceiver link channel manager.But when I open the heat map window the eyediagram is just a small blue line at the center with eyewidth/height ratio 1.
Please let me know what could be reasons for this?
- SK_VA6 years ago
I could see in Strartix 10 device errata that "On-die instrumentation (ODI) (Eye-Q) is not available in Intel Stratix 10 devices that use the transceiver L-tile".
Does this mean that eye diagram cannot be plotted for L tile strartix 10 devices?
I am using 1SG280LN2F43E2VG (L- tile device) in my design.
