Pre emphasis and Equalization in Stratix 10
As I understand it, you have some inquiries related to the explanation references for S10 PMA settings ie VOD, pre-emphasis and equalization. For your information, based on my understanding, there is no specific documentation on this. However, on the high level, the following might be helpful to you:
1. VOD would affect the eye opening of the TX output voltage swing. The high the VOD value, the larger the voltage swing.
2. pre-emphasis would affect the rising and falling edge. You would need to tune to the optimal settings which can give you optimal eye.
3. RX equalization - generally these parameters would help to boost the eye of the received signals
Specific to S10 TX PMA settings, you may refer to the following estimator which will provide you a better graphical illustration on the VOD and pre-emphasis settings.
Note that the required combination of PMA settings would be dependent on your board. You would need to tune the settings to achieve your target BER.
Chee Pin
Can I use an example design targeting H Tile stratix 10 device for L Tile Stratix device.
Sanju
