Pre emphasis and Equalization in Stratix 10
As I understand it, you have some inquiries related to the explanation references for S10 PMA settings ie VOD, pre-emphasis and equalization. For your information, based on my understanding, there is no specific documentation on this. However, on the high level, the following might be helpful to you:
1. VOD would affect the eye opening of the TX output voltage swing. The high the VOD value, the larger the voltage swing.
2. pre-emphasis would affect the rising and falling edge. You would need to tune to the optimal settings which can give you optimal eye.
3. RX equalization - generally these parameters would help to boost the eye of the received signals
Specific to S10 TX PMA settings, you may refer to the following estimator which will provide you a better graphical illustration on the VOD and pre-emphasis settings.
Note that the required combination of PMA settings would be dependent on your board. You would need to tune the settings to achieve your target BER.
Chee Pin
- SK_VA6 years ago
Can I use an example design targeting H Tile stratix 10 device for L Tile Stratix device.
Sanju
