BVola
6 years agoPower Delivery Network tool says I need very few capacitors.
Running PDN for Cyclone IV results show only 4 capacitors required, based on results from EPE. I can even change current to 1 amp and it still only requires 5 caps. Is this right? PDN attached.
ak6dn
6 years agoYou have no entry for your core clock frequency. Power to the core will vary dramatically with frequency and % utilization.
Same for I/O power. Static load is not as much a determining factor as is dynamic I/O switching frequency.
BVola
6 years agoThe power estimator uses the clock frequency to calculate dynamic power, so that's already accounted for. Further, the Core Clock field is "N/A", and can't be changed (the popup note indicates that you need to be in "custom mode" to enter that. Not even sure HOW to enter custom mode).
