Power Delivery Network tool says I need very few capacitors.
Running PDN for Cyclone IV results show only 4 capacitors required, based on results from EPE. I can even change current to 1 amp and it still only requires 5 caps. Is this right? PDN attached.
- YuanLi_S_Intel
This thread will be transitioned to community support. If your question is not addressed yet or you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
- BVola
Nothing has changed. Do I trust the power estimator? Do I trust the PDN tool?
- SreekumarR_G_Intel
can i know you guys facing still issue the same issue ?
- ak6dn
Well in that case I don't believe the spreadsheet at all. A 1.2V Vcore at 20mA and a recommended 5ohm target impedance for the power rail are completely unrealistic values. I don't know what inputs you fed into Quartus to generate this spreadsheet but I would go back to the source. Something in your core and I/O clock setup is not correct.
- ak6dn
You have no entry for your core clock frequency. Power to the core will vary dramatically with frequency and % utilization.
Same for I/O power. Static load is not as much a determining factor as is dynamic I/O switching frequency.
- BVola
The power estimator uses the clock frequency to calculate dynamic power, so that's already accounted for. Further, the Core Clock field is "N/A", and can't be changed (the popup note indicates that you need to be in "custom mode" to enter that. Not even sure HOW to enter custom mode).
- BVola
Everything came right from the power estimator; I was also a little surprised at how low the core current was. I revisited my power calculation, and I changed the I/O load capacitance. It's not clear if the load capacitance column in the power estimator is TOTAL capacitance or capacitance-per-pin. I initially assumed that it was per pin. I changed it to total, which gave me 1300pF (130 pins), which caused the current to jump to about 900 mA. Still, changing that number had very little effect on number of capacitors. And, as I mentioned, I can just arbitrarily put high current values into the PDN tool and still get very few capacitors.
(Full disclosure: I cheated and lumped all my I/O into one module; that shouldn't make a difference).
- ak6dn
Your power rail currents range from 10mA(min) to 40mA(max) in the spreadsheet.These are extraordinarily low numbers and very likely incorrect.
