17 years agoPorting from Xilinx to Altera
Hi everybody, we just started with a new project which will use an Cyclone III. We ant to reuse as much of our previous code which was done for Xilinx FPGA. Most file are quite genric, but so...
17 years agoHi Rysc
Thanks for your response. I found the user guides section on the web, which is what I was looking for - has info on mem, pll etc so possibly my documentation needs have been forfilled. I created a PLL through the megawizard and was happy to find that the resulting VHD file was referencing the altera_mf in the same way that I did it manually. The problem that I currently face in using the megawizard is that I have to use it each time I want to ie: create a PLL with a different mult/div ratio, as I cant bring those generics out of the wrapper entity. I would rather have one PLL file that has some flexiblilty rather than multiple 'dedicated' PLL's. I think I really only need to convert the DCM's and the BRAMs across as the rest is just VHDL. I'll probably use the megawizard output as a reference and then make my custom file, bringing out the generics that I want to keep flexible, plus maybe add a few comments to attempt to keep the confusion to a minimum :)
