rshal2's avatar
rshal2
7 years ago
porting from CYCLON-V to ARRIA-V
We need to port simple application which uses ethernet driver in arm HPS from cyclon-v kit to arria-v kit.
I've tried to find any material about this issue, but didn't find any.
Can anyone give some hints what should we take care of when doing such porting ?
Thank you,
ranran
  • Both devices have the same Cortex A9 processor, so software-wise, you probably don't need to do much there. Hardware-wise, you'll probably need to go through the HPS IP parameter editor to set up and generate the system again, and you'll have to choose new I/O pins for the interface.
    #iwork4intel
  • rshal2's avatar
    rshal2
    Thank you very much for reply.
    Is this process you've mention done as part of PRELOADER ? or part of application ?
    Thank you,
    ranran
  • sstrell's avatar
    sstrell
    #iwork4intel
