rshal2
7 years agoporting from CYCLON-V to ARRIA-V
Hello, We need to port simple application which uses ethernet driver in arm HPS from cyclon-v kit to arria-v kit. I've tried to find any material about this issue, but didn't find any. Can anyone...
- 7 years ago
Both devices have the same Cortex A9 processor, so software-wise, you probably don't need to do much there. Hardware-wise, you'll probably need to go through the HPS IP parameter editor to set up and generate the system again, and you'll have to choose new I/O pins for the interface.
#iwork4intel
rshal2
7 years agoHello,
Thank you very much for reply.
Is this process you've mention done as part of PRELOADER ? or part of application ?
Thank you,
ranran
