12 years agoPorting Custom Code on SD
Hi, I have successfully managed to boot Linux on Cyclone 5 SoC with SD card. I also run 2 applications (hello & led_blink) which were already present in the prebuilt sd card image taken off ...
12 years agoThanks for your suggestion Galfonz.
It took me a while to understand that I could edit and debug the apps present in the prebuilt image file on the SD card. The learning curve is steep! I eventually setup Ethernet and use DS-5 to debug & run my application on Linux. Anybody looking to do something similar can refer to this tutorial I came across https://www.youtube.com/watch?v=zcgqejkywoc Thanks :)
