17 years agoporting code from SRAM to SSRAM, bursting confusion
Hi all, I'm trying to port some code which used an SRAM chip on a DE1 board, to use the SSRAM chip on a DE2-70 board. My main concern and confusion is the fact that SSRAM uses bursting. ...
17 years agoI've made my own controller based on that one. That controller does not allow arbitrary reads for one simple reason: it deselects the chip select while it is waiting for data to return. To make it work, simply assign the chipselect signal to the 3 SSRAM chipselects.
Though, the controller should work if you're using it only with the nios cpu. Why didn't it work for you?
