20 years agoPortable Reference Platform
The portable reference platform (http://www.niosforum.com/pages/project_details.php?p_id=77&t_id=45) is available for download on the System Design Projects Page. It shows how to use Nios II and SOPC...
19 years agoHi skravats.
I've a question for you about your Por Ref Plat. The exe file at the bottom of the page, is a kind of "filling system" where the user can personalize his own system doing the appropriate connection? Let me explain my project. A CMOS camera, I2C\SCCB\ interface, is connected to PROTO1 block by a Daughter Board. Using the altera developmenat board EP2C35, fpga Cyclone II, i must catch pixels and whole frames from that camera using Nios II and Quartus II software. My first problem is how to read datas from camera because i tried to use Pios for doing this after have seen the templates files on Nios II software. I thougt that the method used to catch the switches status was the right way for catching datas from an external peripheral like a camera,so pios should be ok. But, this solution wasn't right. Can you explain me,what have i to use? On while i will read your exe file. I wanna ask you this first because if this is not the right solution for my project i try to find other infos. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/unsure.gif Many thanks.
