9 years agoPort number limitation prevents my codes from compiling
I have two questions. What I want to do is : I want to send 144 8bit numbers from my computer to FPGA, and let the FPGA store the numbers in memory in the FPGA. And let the verilog bloc...
9 years ago --- Quote Start --- I will use "Type A to B USB cable" contained in FPGA DE1-SoC to connect PC to FPGA. --- Quote End --- On the DE1-SOC the USB-B connection is for the Altera USB Blaster II programmer via JTAG. You really don't intend to use that, correct? There is a mini USB B connection that is a USB serial to UART slave connection implemented via an FTDI FT232R USB-UART bridge. Is this what you intend to use? If so, this will interface as a standard serial COM port on your PC, and connects to the HPS UART in the FPGA.
