9 years agoPort number limitation prevents my codes from compiling
I have two questions. What I want to do is : I want to send 144 8bit numbers from my computer to FPGA, and let the FPGA store the numbers in memory in the FPGA. And let the verilog bloc...
9 years ago --- Quote Start --- Thank you Carlhermann Your suggenstion that receive the numbers through address is good solution for me. --- Quote End --- How do you physically expect to connect your FPGA to the PC? Thru a serial connection (like an RS232 link), or etherNet, PCI bus, or PCIE bus? Or as just some bits that you toggle in a GPIO port on an expander card? Each of these methods have very different levels of performance and complexity. Just wondering.
