8 years agoPLL's in Cyclone V
I am trying to use the output of a PLL to drive a logic in FPGA. I'm not sure which clock should be connected as the 'refclk' for the PLL and how the 'outclk' of the PLL should clock my logic. I have tried using a 50MHz clock (PIN AF_14) as a refclk for the PLL, and used the PLL 'outclk' as a clock input but my logic does produce any output. Could you please help? Also, when I check my logic in ModelSim, the correct results are obtained. Thank you.11 Replies
Apologies for the late reply. I did a lot of trial and error tests. I was able to achieve higher clock speeds. But I wanted to confirm if this is the right way. Here is the top level code: module top( input clk, input rst, input driver_clk, output pll_out, output locked_port, output data ); driver d1( .clk(driver_clk), .rst(rst), .data_out(data) ); pll pll_inst ( .refclk (clk), // refclk.clk .rst (rst), // reset.reset .outclk_0 (pll_out), // outclk0.clk .locked (locked_port) // locked.export ); endmodule The pll_out port is connected to PIN_AH12 and I am using driver_clk is connected to PIN_AJ12 which is the the clock input for the driver module. The 'data' port is connected to HSMC pin 'PIN_B13' and I have also assigned the 'pll_outclk' as a GCLK. Is this the right way to go about? Because my output signal have a lot of jitters and distortions. Thanks for all your help.
